Rules Security
nimol
Version: 1022
Rules Security
Post by nimol »
I need to apply security to rules, i.e. users should not be able to see cube rules and not be able to amend them. How do you achieve that?
Re: Rules Security
Users cannot ammend rules. Only administrators are able to edit rules.
However as far as I am aware there is no way to suppress the display of rules under the cubes. (and even if you could a user can always click on "trace calculation" in the cube viewer and see the rule that is in effect.)
qml
Excel Version: 2007 - 2016
Re: Rules Security
Post by qml »
More specifically, you need at least READ access to a cube to view its rules and at least ADMIN access to a cube to edit rules. You do not have to be a member of any of the 3 standard "Admin" groups.
Kamil Arendt
nimol
Version: 1022
Re: Rules Security
Post by nimol »
Thanks for explanation. Talking about disabling functions, are you are able to disable menu choice "display control objects" for users?
