Just logged a fault with the GUI when creating a new action button using TM1 9.5.2 and Excel 2003.
Full details are attached but to summarise;
create an action button to run a TI that includes parameters
user has multiple servers available from their admin host list
select server and TI to run
add link to cell in worksheet for value to feed to 1st parameter
on clicking OK, GUI will revert back to the 1st server in the list, not the one selected.
reselecting the correct server does not reinstate the cell references just picked
The work around is easy - pick the server and TI ONLY, click OK, then right click the new button and go back to properties. The values can then be edited correctly. Its a daft error to have tho and i'm sure will catch others out which is why i have raised it with IBM.
PDF of screenshots to recreate error and workaround solution
(204.9 KiB) Downloaded 1026 times
If this were a dictatorship, it would be a heck of a lot easier, just so long as I'm the dictator. Production: Planning Analytics 64 bit 2.0.5, Windows 2016 Server. Excel 2016, IE11 for t'internet
IBM have confirmed the defect and is now being managed via APAR PM21446. This APAR will be published to ibm.com after an internal review .
