i have created a model in TM1 architect, i've created the application in contributor, handled all the rights affectations and i've added groups and users but the problem is when i login using a client username i don't find any application loaded!!!!
could any one give me a hint pleaaaaaaaase, it's urgent.
i created the groups and i affected users to these groups in tm1 architect, and in tm1 contributor i added the appropriate rights (edit, view, submit and review) to eatch group. i don't know if this what you ment by application folders. plz if there is any step missing tell me what to do
sara wrote:i don't know if this what you ment by application folders. plz if there is any step missing tell me what to do
If you look at the object tree in Architect you will see an object called "Applications". This is the apllications folder and it is where you would likely put views and reports. if you don't give rights to this object then no one will be able see what's underneath it.
