Different dimensions in cubes
Posted: Mon Apr 04, 2011 7:12 pm
I am new to TM1. I have faced a problem like there are three cubes in which two cubes have same number of dimensions and another cube had one less number of dimension, now the issue is when i am writing a rule for this i am not getting the exact vale i mean calculation is not happened.
Eg:
Cube A has 9 dimesions.
Cube B has 9 dimensions
Cube C has 8 dimensions.
when i am writing rule for Cube B= Cube A * Cube C(8 dim) i am not getting the value, but when i add one more dimension to the Cube C and calculate the calculation is happening correctly.
Any suggestions Why it is happening like this?
thanking you
Eg:
thanking you
