I am new to TM1. I have faced a problem like there are three cubes in which two cubes have same number of dimensions and another cube had one less number of dimension, now the issue is when i am writing a rule for this i am not getting the exact vale i mean calculation is not happened.
Eg:
Cube A has 9 dimesions.
Cube B has 9 dimensions
Cube C has 8 dimensions.
when i am writing rule for Cube B= Cube A * Cube C(8 dim) i am not getting the value, but when i add one more dimension to the Cube C and calculate the calculation is happening correctly.
Any suggestions Why it is happening like this?
thanking you
Different dimensions in cubes
sreecharan
- Version: 9.5.1
- rkaif
- Version: 9.1 or later
Re: Different dimensions in cubes
Welcome to the forum,
First of all I would ask you to read this: http://www.tm1forum.com/viewtopic.php?f=3&t=1037
Also it will be a lot easier for us to help you if you can share the Rule which you are having problems with.
Cheers!
Rizwan Kaif
Rizwan Kaif
