What-If analysis with TM1.
deepu_sree
OLAP Product: IBM TM1
Version: 9.5
Post by deepu_sree »
Can somebody give me a few ideas/inbuilt mechanisms in TM1 which help you do What-If analysis?
I'm completely clueless about What-If analysis and thats why such a vague question. Sorry about it.
Deepu.
Version: PA 2.0.7
Re: What-If analysis with TM1.
Post by jim wood »
Hi Deepu,
There are some elements you can do within Excel, for example spreading and there are things you do via TM1 Contributor, but on the whole TM1 itself is like a starting block. If you want it to do something you build it by using either rules (calculation language) or TI (Turbo Integrator).
For more information might I suggest you look at OLAPedia or check out the IBM web site,
Jim.
csjean
Version: 9.5 9.5.1 9.5.2
Post by csjean »
Hi Deepu,
Depending on your needs:
  • Why you need the what-if analysis
  • What you will do with it once it's finished
  • What kind of "ifs" we are talking about (driver based or "finger" based variations).
There are a lot of things you can do with TM1 and a lot of different ways to do them:
  • Use sandboxes
  • Use driver cubes and rules
  • Use TIs
  • Spread values with the many spreading functions.
  • None of the above
  • All of the above
As Jim said, you should lookup IBM's website and familiarize yourself with the different TM1 features.
Hope this helps.
Cheers!
Claude-Sebastien Jean
Senior Consultant in Information Technology
Keyrus Canada
www.keyrus.ca
