How to create Attributes using Dimension worksheets.
Posted: Mon Jan 17, 2011 9:26 am
by Radhika
I am using Dimesnion Worksheets to create dimensions.
Can we create Attributes using Dimension worksheets. If yes, request you to let me know the process.
TM1 Version: 9.5.1, OS: Windows 2003, Excel Edition: 2003.
Thanks & Regards,
Radhika
Re: How to create Attributes using Dimension worksheets.
Posted: Mon Jan 17, 2011 9:39 am
by Steve Vincent
If they are only ever created or edited via the XDI then use any column after C to add DBRA formula. If at any point a dim is edited in the server explorer and the user chooses to save over the XDI, the other columns in the XDI will be wiped out.
Posted: Mon Jan 17, 2011 1:44 pm
by Gabor
Yes, this is possible but not officially supported as far as I know, so the usage might cause other trouble, but I am not aware of it.
I use this from time to time instead writing a TI and loop through a list of attribute elements to edit larger attribute dimensions.
Let's say you have a dimension test.dim with respective attribute dimension }elementattributes_test.dim.
If you create a file }elementattributes_test.xdi you can use this to edit attribute elements.
N in col A creates numeric elements as known from other dimension worksheets, letter A creates an alias attribute and G (instead S) comes back with a text attribute.
Gabor
Posted: Mon Jan 17, 2011 9:34 pm
A simpler and less risky approach to creating an }ElementAttributes XDI would be to use an action button to run a generic process to insert a dimension attribute. That way the dimension can be edited entirely from within Excel.
For columns D onwards you can use something like DINNM(DIMIX()) combination with COLUNM()-3 to return attribute values which will automatically update as new attributes are added.
Posted: Thu Jan 20, 2011 11:05 am
by Radhika
Thank you for the response and approach.
Thannks,
Radhika
