I am using Dimesnion Worksheets to create dimensions.
Can we create Attributes using Dimension worksheets. If yes, request you to let me know the process.
TM1 Version: 9.5.1, OS: Windows 2003, Excel Edition: 2003.
Thanks & Regards,
Radhika
How to create Attributes using Dimension worksheets.
- Steve Vincent
- Version: 10.2.2 FP1
Re: How to create Attributes using Dimension worksheets.
If they are only ever created or edited via the XDI then use any column after C to add DBRA formula. If at any point a dim is edited in the server explorer and the user chooses to save over the XDI, the other columns in the XDI will be wiped out.
Gabor
- Version: [2.x ...] 11.x / PAL 2.1.13
- Excel Version: Excel 2016-2021-365
Yes, this is possible but not officially supported as far as I know, so the usage might cause other trouble, but I am not aware of it.
I use this from time to time instead writing a TI and loop through a list of attribute elements to edit larger attribute dimensions.
Let's say you have a dimension test.dim with respective attribute dimension }elementattributes_test.dim.
If you create a file }elementattributes_test.xdi you can use this to edit attribute elements.
N in col A creates numeric elements as known from other dimension worksheets, letter A creates an alias attribute and G (instead S) comes back with a text attribute.
Gabor
Gabor
A simpler and less risky approach to creating an }ElementAttributes XDI would be to use an action button to run a generic process to insert a dimension attribute. That way the dimension can be edited entirely from within Excel.
For columns D onwards you can use something like DINNM(DIMIX()) combination with COLUNM()-3 to return attribute values which will automatically update as new attributes are added.
Radhika
- Version: v9.4.1
- Excel Version: Microsoft Excel 2003
Thank you for the response and approach.
Thannks,
Radhika
Thannks,
Radhika
