Advanced Subset Editor
Posted: Wed Jan 12, 2011 4:45 pm
Unable to find advanced subset editor option in the normal subset editor window in version 9.5 of TM1
Discussing all things TM1, Planning Analytics, PAx and PAW
https://www.tm1forum.com/
I think this is only avaiable in TM1 web, is that what you are using?rangansingham wrote:Unable to find advanced subset editor option in the normal subset editor window in version 9.5 of TM1
Agreed. Moved to the general TM1 forum.lotsaram wrote:There is no such thing as "advanced subset editor" in Perspectives.
This thread should not be in posted under bugs. Please review the posting guidelines.
I believe you are looking for the subset editor where you can view the hierarchy twice in the same window and drag / drop between them etc? it is only available in TM1 web, it has never made it to perspectives although when first shown it i commented we'd bite our own arms off to get it in perspectives.rangansingham wrote:No I was trying to find this under Perspectives.
Indeed. But also note that you can open subset editor for a dimension from within a view only once. So at least one of the subset editor windows must be opened directly from the dimension.Steve Rowe wrote:N...you can open the subset editor twice for the same dimension and copy and paste, not quite drag and drop I know....
Instead of opening a second Subset Editor from the dimension list you can open the second Subset Editor using the option Edit->Insert Subset from the first Subset Editor - but... do not forget to click Cancel after you're done to close the second Subset Editor or you'll end up with a custom roll-up...stephen waters wrote:Indeed. But also note that you can open subset editor for a dimension from within a view only once. So at least one of the subset editor windows must be opened directly from the dimension.Steve Rowe wrote:N...you can open the subset editor twice for the same dimension and copy and paste, not quite drag and drop I know....
