Advanced Subset Editor
rangansingham
- OLAP Product: tm1
- Version: 9.5
Unable to find advanced subset editor option in the normal subset editor window in version 9.5 of TM1
- stephen waters
- Version: 10_2_2
- Excel Version: Excel 2010
Re: Advanced Subset Editor
I think this is only avaiable in TM1 web, is that what you are using?rangansingham wrote:Unable to find advanced subset editor option in the normal subset editor window in version 9.5 of TM1
rangansingham
- OLAP Product: tm1
- Version: 9.5
No I was trying to find this under Perspectives.
There is no such thing as "advanced subset editor" in Perspectives.
This thread should not be in posted under bugs. Please review the posting guidelines.
Agreed. Moved to the general TM1 forum.lotsaram wrote:There is no such thing as "advanced subset editor" in Perspectives.
- Steve Vincent
- Version: 10.2.2 FP1
I believe you are looking for the subset editor where you can view the hierarchy twice in the same window and drag / drop between them etc? it is only available in TM1 web, it has never made it to perspectives although when first shown it i commented we'd bite our own arms off to get it in perspectives.rangansingham wrote:No I was trying to find this under Perspectives.
rangansingham
- OLAP Product: tm1
- Version: 9.5
Thank you for your guidence.
- Steve Rowe
Note thought that you can open the subset editor twice for the same dimension and copy and paste, not quite drag and drop I know....
- stephen waters
- Version: 10_2_2
Indeed. But also note that you can open subset editor for a dimension from within a view only once. So at least one of the subset editor windows must be opened directly from the dimension.Steve Rowe wrote:N...you can open the subset editor twice for the same dimension and copy and paste, not quite drag and drop I know....
- Michel Zijlema
- OLAP Product: TM1, PALO
Instead of opening a second Subset Editor from the dimension list you can open the second Subset Editor using the option Edit->Insert Subset from the first Subset Editor - but... do not forget to click Cancel after you're done to close the second Subset Editor or you'll end up with a custom roll-up...stephen waters wrote:Indeed. But also note that you can open subset editor for a dimension from within a view only once. So at least one of the subset editor windows must be opened directly from the dimension.Steve Rowe wrote:N...you can open the subset editor twice for the same dimension and copy and paste, not quite drag and drop I know....
Michel
