Advanced Subset Editor
rangansingham
OLAP Product: tm1
Version: 9.5
Post by rangansingham »
Unable to find advanced subset editor option in the normal subset editor window in version 9.5 of TM1
stephen waters
Version: 10_2_2
Excel Version: Excel 2010
Re: Advanced Subset Editor
Post by stephen waters »
rangansingham wrote:Unable to find advanced subset editor option in the normal subset editor window in version 9.5 of TM1
I think this is only avaiable in TM1 web, is that what you are using?
rangansingham
OLAP Product: tm1
Version: 9.5
No I was trying to find this under Perspectives.
There is no such thing as "advanced subset editor" in Perspectives.
This thread should not be in posted under bugs. Please review the posting guidelines.
lotsaram wrote:There is no such thing as "advanced subset editor" in Perspectives.
Agreed. Moved to the general TM1 forum.
Steve Vincent
Version: 10.2.2 FP1
Post by Steve Vincent »
rangansingham wrote:No I was trying to find this under Perspectives.
I believe you are looking for the subset editor where you can view the hierarchy twice in the same window and drag / drop between them etc? it is only available in TM1 web, it has never made it to perspectives although when first shown it i commented we'd bite our own arms off to get it in perspectives.
rangansingham
OLAP Product: tm1
Version: 9.5
Thank you for your guidence.
Note thought that you can open the subset editor twice for the same dimension and copy and paste, not quite drag and drop I know....
stephen waters
Version: 10_2_2
Steve Rowe wrote:N...you can open the subset editor twice for the same dimension and copy and paste, not quite drag and drop I know....
Indeed. But also note that you can open subset editor for a dimension from within a view only once. So at least one of the subset editor windows must be opened directly from the dimension.
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Post by Michel Zijlema »
Instead of opening a second Subset Editor from the dimension list you can open the second Subset Editor using the option Edit->Insert Subset from the first Subset Editor - but... do not forget to click Cancel after you're done to close the second Subset Editor or you'll end up with a custom roll-up...
Michel
