cfg file.
viswaraju
OLAP Product: IBM COGNOS TM1
Version: 9.5
cfg file.
Post by viswaraju »
hi,
i tried to install TM1 9.5 with perspective client and in Pdata i was unable to find the config file and also license file was is tm1p8.lic and i did not find the Sdata.Any suggestion please. I was unable to configure the local dataserver.
thanking you
ravi
OLAP Product: cognos
Version: tm1 9.5
Re: cfg file.
Post by ravi »
Hi Viswaraju,
Could you please re-check in the below location C:\Program Files\Cognos\TM1\Custom\TM1Data
And see how many TM1 data folders you have-
1)PData
2)PlanSamp
3)Rules_Guide_Data
4)SData
5)TI_Data
you should have above TM1 data folders.
Also check in TM1 perspective sever explorer -file->options->Local server(Data directory) and browse data directory to your local server.
Ravi
Re: cfg file.
ravi wrote: Could you please re-check in the below location location C:\Program Files\Cognos\TM1\Custom\TM1Data
And see how are TM1 data folders you have-
1)PData
2)PlanSamp
3)Rules_Guide_Data
4)SData
5)TI_Data
It also depends on the operating system that he used to install it on. If it was Vista or Windows 7, Windows won't allow data files to be stored in the same path as the program files. This can result in the data files being in the users roaming profile folders without the user being aware of it. I did raise this as an issue with IBM some time ago (specifically, that they need to rectify the installation package so that by default it sends the data files to somewhere other than the C:\Program Files\ path), but I don't know whether they've fixed it in 9.5.1. The response that I got to the bug report indicated that they didn't quite "get" what the problem was.
viswaraju
Version: 9.5
Re: cfg file.
Post by viswaraju »
hi Boss Alan,
the operating system i am using is windows XP.
thanking you.
Re: cfg file.
viswaraju wrote:hi Boss Alan,
"Imperator" will do fine. :|
viswaraju wrote:the operating system i am using is windows XP.
I can see what you've done now.
When you did the installation you selected the TM1 Perspectives option. This will install the pData sample.
pData is designed to be used only by someone who's running stand-alone Perspectives with a local server. (As opposed to one which is running as a service, even on the same machine.) Consequently there is no tm1s.cfg file in the pData directory, since local servers ignore that anyway.
To get sData or the Planning Sample (both of which do have configuration files since they're intended to be run as services, not as local servers), uninstall your existing TM1 installation (just to be safe; it may not strictly speaking be necessary to do that but I would anyway) and reinstall selecting the option TM1 - Install TM1 Server and Clients. At some point (assuming that you select a Custom install rather than a standard one) you'll need to specify the sample databases that you want to install. Read the installation instructions very carefully at this point, because the dialog is fairly fiddly.
Incidentally, the licence file tm1p8.lic has no bearing on the version; its purpose is to allow you to use the Perspectives version of the client, rather than the base Client which is designed for non-administrators. The licence is for Perspectives, not the servers. The "8" in the name doesn't make it version-specific.
