Subset Element Exists
Is there such a TI function as SUBSETELEMENTEXISTS or similar. I've checked the help files and can't find anything.
Is there a way round this in TI, without using DIMIX?
Matt
Matt
- Martin Ryan
Re: Subset Element Exists
You could use a while loop with the functions SubsetGetSize and SubsetGetElementName.
top=SubsetGetSize('Dim', 'Sub');
count=0;
SubElemExists=0;
while(count<top);
if(SubsetGetElementName('Dim', 'Sub', count)@=soughtElement);
SubElemExists=1;
endif;
count=count+1;
end;
Reason: Forgot to add the "count+1";
- bihints.com
- Version: 9.0.3
- Excel Version: 2003
use MDX
SubsetCreateByMDX('Subset 2','{EXCEPT( {[dim].[Subset 1]}, {[dim].[element1]} )}');
then compare the sizes of 'Subset 1' and 'Subset 2' with SubsetGetSize
if both subsets are the same size then it means element1 is not in 'Subset 1'.
Thanks Martin,
Whereabouts in the code should I put the SUBSETELEMENTINSERT function?
Matt
Matt
- Martin Ryan
At the end, like so...
count=0;
SubElemExists=0;
while(count<top);
SubElemExists=1;
endif;
count=count+1;
end;
# If element wasn't found in the subset already, then add it in.
if(SubElemExists)=0;
SubsetElementInsert('Dim', 'sub', soughtElement, 1);
endif;
Nearly there . . . .
Count = 1, instead of Count = 0, but the last element in my list is entered into the subset twice, any ideas why?
TIA
Matt
TIA
Matt
Moving up count = count + 1 :
count=1;
SubElemExists=0;
while(count<top);
count=count+1;
SubElemExists=1;
endif;
end;
endif;
This means that ONLY the last element of the list is added to the subset. Still not quite right.
count=1;
SubElemExists=0;
while(count<top);
count=count+1;
SubElemExists=1;
endif;
end;
endif;
I don't think that you should have movedMattyG wrote:Moving up count = count + 1 :
count=1;
SubElemExists=0;
while(count<top);
count=count+1;
SubElemExists=1;
endif;
end;
endif;
count=count+1;
up there; it means that you're ignoring the 1st element in the subset.
(Also 1 minor tweak that I'd suggest;
SubElemExists=1;
count = top;
endif;
But as to your actual problem... you ARE doing this on the Metadata tab and not one of the others, yes?
Hi Alan,
This is the code as it stands, which does what I want it to do. Moving the Count = Count + 1 up just puts the last element in the list into the subset.
I have put + 1 on the end of Top = SUBSETGETSIZE ( ' Dim ', ' Sub ' ), because without it the last element in the list is added twice into the subset.
I was doing all this on the Data tab, but I've just tried moving it to the Metadata tab, and the results are the same.
IF ( SUBSETEXISTS ( ' Dim ', ' Sub ' ) = 0 ) ;
SUBSETCREATE ( ' Dim ', ' Sub ' ) ;
ENDIF ;
Top = SUBSETGETSIZE ( ' Dim ', ' Sub ' ) + 1 ;
Count = 1 ;
SubsetElementExists = 0 ;
WHILE ( Count < Top ) ;
IF ( SUBSETGETELEMENTNAME ( ' Dim ', ' Sub ', Count ) @= SoughtElement) ;
SubsetElementExists = 1 ;
Count = Top ;
ENDIF ;
Count = Count + 1 ;
END ;
IF ( SubsetElementExists = 0 ) ;
SUBSETELEMENTINSERT ( ' Dim ', ' Sub ', SoughtElement, 1 ) ;
ENDIF ;
However, I would still like to incorporate the functionality of rebuilding the subset each time the process is run. Any ideas?
Matt
ENDIF ;
Count = 1 ;
Count = Top ;
ENDIF ;
Count = Count + 1 ;
END ;
ENDIF ;
Matt
