Subset Element Exists
MattyG
Post by MattyG »
Is there such a TI function as SUBSETELEMENTEXISTS or similar. I've checked the help files and can't find anything.
Is there a way round this in TI, without using DIMIX?
Matt
Martin Ryan
Re: Subset Element Exists
Post by Martin Ryan »
You could use a while loop with the functions SubsetGetSize and SubsetGetElementName.
top=SubsetGetSize('Dim', 'Sub');
count=0;
SubElemExists=0;
while(count<top);
if(SubsetGetElementName('Dim', 'Sub', count)@=soughtElement);
SubElemExists=1;
endif;
count=count+1;
end;
Martin
Reason: Forgot to add the "count+1";
Jodi Ryan Family Lawyer
bihints.com
Version: 9.0.3
Post by bihints.com »
use MDX
SubsetCreateByMDX('Subset 2','{EXCEPT( {[dim].[Subset 1]}, {[dim].[element1]} )}');
then compare the sizes of 'Subset 1' and 'Subset 2' with SubsetGetSize
if both subsets are the same size then it means element1 is not in 'Subset 1'.
MattyG
Post by MattyG »
Thanks Martin,
Whereabouts in the code should I put the SUBSETELEMENTINSERT function?
Matt
Martin Ryan
At the end, like so...
count=0;
SubElemExists=0;
while(count<top);
SubElemExists=1;
endif;
count=count+1;
end;
# If element wasn't found in the subset already, then add it in.
if(SubElemExists)=0;
SubsetElementInsert('Dim', 'sub', soughtElement, 1);
endif;
MattyG
Post by MattyG »
Nearly there . . . .
Count = 1, instead of Count = 0, but the last element in my list is entered into the subset twice, any ideas why?
TIA
Matt
MattyG
Post by MattyG »
Moving up count = count + 1 :
count=1;
SubElemExists=0;
while(count<top);
count=count+1;
SubElemExists=1;
endif;
end;
# If element wasn't found in the subset already, then add it in&#46;
endif;
This means that ONLY the last element of the list is added to the subset. Still not quite right.
MattyG wrote:Moving up count = count + 1 :
count=1;
SubElemExists=0;
while(count<top);
count=count+1;
SubElemExists=1;
endif;
end;
endif;
I don't think that you should have moved
count=count+1;
up there; it means that you're ignoring the 1st element in the subset.
(Also 1 minor tweak that I'd suggest;
SubElemExists=1;
count = top;
endif;
There's no point looping through the other elements if you find the one you're after.
But as to your actual problem... you ARE doing this on the Metadata tab and not one of the others, yes?
MattyG
Post by MattyG »
Hi Alan,
This is the code as it stands, which does what I want it to do. Moving the Count = Count + 1 up just puts the last element in the list into the subset.
I have put + 1 on the end of Top = SUBSETGETSIZE ( ' Dim ', ' Sub ' ), because without it the last element in the list is added twice into the subset.
I was doing all this on the Data tab, but I've just tried moving it to the Metadata tab, and the results are the same.
IF ( SUBSETEXISTS ( ' Dim ', ' Sub ' ) = 0 ) ;
SUBSETCREATE ( ' Dim ', ' Sub ' ) ;
ENDIF ;
Top = SUBSETGETSIZE ( ' Dim ', ' Sub ' ) + 1 ;
Count = 1 ;
SubsetElementExists = 0 ;
WHILE ( Count < Top ) ;
IF ( SUBSETGETELEMENTNAME ( ' Dim ', ' Sub ', Count ) @= SoughtElement) ;
SubsetElementExists = 1 ;
Count = Top ;
ENDIF ;
Count = Count + 1 ;
END ;
IF ( SubsetElementExists = 0 ) ;
SUBSETELEMENTINSERT ( ' Dim ', ' Sub ', SoughtElement, 1 ) ;
ENDIF ;
However, I would still like to incorporate the functionality of rebuilding the subset each time the process is run. Any ideas?
Matt
