I have a Contributor application, when a user with admin-rights opens the app everything is fine. When another user opens the application he gets the following error:
An error occured on the TM1-Server.
:com.cognos.ccl4j.exceptions.CCLNullArgumentException (rootcom.cognos.ccl4j.exceptions.CCLNULLArgumentException):[CCLMSG: system text='Argument value is null']
Any idea what might have caused this?
Thanks a lot,
Toto
Contributor - CCLNullArgumentException
soprano96
- Version: 9.5
Re: Contributor - CCLNullArgumentException
Toto, did you ever resolve this problem? I am having the same issue and cannot figure out the problem. It has something to do with security permissions, but I cannot for the life of me figure out where these permissions are.Toto wrote:Hello,
Thanks a lot,
Toto
szeth
- Version: 10.1.1
Had this same error in version 10.1.1. Admins could log in without issue to the application. Non-admins could not. The day before non-admins had been able to log into the application, so this was, needless to say, perplexing.
Yesterday I re-created the approval hierarchy within TM1. And the security in TM1 Applications remained attached to the app, so I didn't figure I needed to do anything to it. But I'd tried everything else I could think of, so I decided to delete the security in TM1 Applications and re-import it. When I logged back in again with non-admin rights, the error message was gone.
Hope this helps someone,
Gavin
Gavin
sankeerthv
- OLAP Product: Cognos EP 8.4, 10.1 and TM1 10
- Version: Tm1 10.1.1 10.2
- Excel Version: MS Office 2007
Re: Contributor - CCLNullArgumentException in TM1
Hello All,
Kindly Help in Solving the same as mentioned above.
Kindly find the screen shot as well for the same,
Problem 1: I am not able to launch the Application Web . Error as Follows.
An exception occurred on the server. Please contact your system administrator. :com.cognos.ccl4j.exceptions.CCLNullArgumentException (root com.cognos.ccl4j.exceptions.CCLNullArgumentException):
[CCLMsg: system text='Argument value is null']
Problem 2: The Same Problem Continues with in PM . I am not able to launch the Application DesignPannel from PM 10.2.
There are only Model Design Panel and Transfer Design Panel. No Application Design Panel.
Kindly help in resolving the same.
- PM Error No application Design Panel.png (166.57 KiB) Viewed 4849 times
- Application Web Error.png (82.33 KiB) Viewed 4849 times
