Apologies if this a basic question
Which below scenario would be "better"?
Scenario A:
One cell in cube A, used to calculate 10 in Cube B, which in turn are used to calculate 10 in Cube C
Or....
Scenario B:
One cell in cube A, used to calculate 100 in Cube C
Another Feeder Question
AnthonyT
- OLAP Product: TM1, EV
- Version: 9.0 9.1 9.4 9.5 10.1 10.2
- Excel Version: 2003 2007 2010 2015
Anthony
That's no moon - that's a space station
Re: Another Feeder Question
Good morning Anthony!
If you want to see the values in cube B adding up or showing in a 0-suppressed view, you need to ensure they are fed.
If not, I don't think there's much difference between the two approaches.
But you will recall that you can save a bit by 'skipping over' intermediate calculations and just feeding the result.
AnthonyT
Hi David
Thanks for the reply - hope things are well?
Cube 2 is being used as a staging area, so that some metrics can be expanded to fill the reporting dates. Cube 3 then uses these values by date, and applies them to another dimension.
I was thinking of doing away with Cube 2, thus reducing one lot of rules and one lot of feeders. Cube 3 is already being fed by Cube 1 anyway.
Thanks again
Thanks again
Anthony
