Using the .net API
Posted: Tue May 25, 2010 1:11 pm
This might be common knowledge/documented/obvious
but.....
In order to run an application (or develop one ) using the TM1 API , you need to use the setup kit to install the .NET API.
I thought it would be sufficient to reference the Applix.TM1.API.dll from a .NET project.
Incidentally does anyone know how to install/wrap up the .NET part without using the full installer?
but.....
