Using the .net API
ParisHilton
OLAP Product: Tm1
Version: 9.5
Excel Version: 2007 2010
Using the .net API
Post by ParisHilton »
This might be common knowledge/documented/obvious
but.....
In order to run an application (or develop one ) using the TM1 API , you need to use the setup kit to install the .NET API.
I thought it would be sufficient to reference the Applix.TM1.API.dll from a .NET project.
Incidentally does anyone know how to install/wrap up the .NET part without using the full installer?
“The way I see it, you should live everyday like its your birthday”
TM1 9.5 Cognos BI 8.4 Excel 2007. 128GB Ram. E7450@2.40Ghz -24 core. Fluffy white dog.
ParisHilton
OLAP Product: Tm1
Version: 9.5
Re: Using the .net API
I discovered this afternoon that you can fire executables remotely, so you can leave your .net application and the .net api on your Tm1 server and kick it off from elsewhere so there isn't really any need to set up the API on other machines.
olapuser
Version: 9.5
Post by olapuser »
As my experience, i just use the one click publish feature.
