find a name of the client in process
borisslu
Post by borisslu »
I want to find a name of the client which runs this process , can someone help me ?
Is it possible to do it in turbo ?
Boris
kpk
OLAP Product: TM1, CX
Re: find a name of the client in process
Post by kpk »
From version 9.? you can use TM1User.
Peter
TM1User()
This function returns a string giving the current TM1Client. When executed in a process that the
user is running directly, it will return the users TM1 client name. When executed in a chore that
the user runs directly, it will also return the users TM1 client name.
If run from a scheduled chore, it will return a name in the form R*<chore name>, for example,
R*UpdateRegionDimension.
Syntax
TM1User()
Best Regards,
Peter
borisslu
Post by borisslu »
thanks,
and for version 8.?
thanks
kpk
Post by kpk »
Unfortunately this function was introduced in one of the 9 versions.
You can define a parameter on the advanced tab and ask your user to complete it at the start of the process. It will be not a fool proof solution.
Peter
Best Regards,
Peter
paulsimon
Version: PA 2.0.5
Post by paulsimon »
You could try the attached. A typical call looks like this:
StringSessionVariable('svWhoAmI');
ExecuteProcess('zTD_Security_Get_User_Name_svWhoAmI') ;
vUser = svWhoAmI ;
It uses MDX to get the name of the current user, which I think was introduced a little earlier than the TM1UserName function in TI, so it may work in your version.
zTD_Security_Get_User_Name_svWhoAmI.zip
(1.1 KiB) Downloaded 434 times
borisslu
Post by borisslu »
thanks you !!!
it is work!!
have a nice day
Boris
