I want to find a name of the client which runs this process , can someone help me ?
Is it possible to do it in turbo ?
Boris
find a name of the client in process
kpk
- OLAP Product: TM1, CX
- Version: TM1 7x 8x 9x 10x CX 9.5 10.1
- Excel Version: XP 2003 2007 2010
Re: find a name of the client in process
From version 9.? you can use TM1User.
Peter
TM1User()
This function returns a string giving the current TM1Client. When executed in a process that the
user is running directly, it will return the users TM1 client name. When executed in a chore that
the user runs directly, it will also return the users TM1 client name.
If run from a scheduled chore, it will return a name in the form R*<chore name>, for example,
R*UpdateRegionDimension.
Syntax
TM1User()
Peter
TM1User()
Syntax
TM1User()
Best Regards,
Peter
Peter
thanks,
and for version 8.?
thanks
and for version 8.?
thanks
kpk
Unfortunately this function was introduced in one of the 9 versions.
You can define a parameter on the advanced tab and ask your user to complete it at the start of the process. It will be not a fool proof solution.
Peter
Peter
Best Regards,
Peter
Peter
- paulsimon
- Version: PA 2.0.5
You could try the attached. A typical call looks like this:
StringSessionVariable('svWhoAmI');
ExecuteProcess('zTD_Security_Get_User_Name_svWhoAmI') ;
vUser = svWhoAmI ;
It uses MDX to get the name of the current user, which I think was introduced a little earlier than the TM1UserName function in TI, so it may work in your version.
vUser = svWhoAmI ;
- zTD_Security_Get_User_Name_svWhoAmI.zip
- (1.1 KiB) Downloaded 466 times
thanks you !!!
it is work!!
have a nice day
Boris
it is work!!
have a nice day
Boris
