TM1 Contributor - approval heirachy is being used
Posted: Fri Jan 29, 2010 4:22 am
by rollo19
.. by another application. Anyone else get this? I'm trying to deploy a contributor application and I get this error "The approval hierarchy is being used by another application."
Has anyone found an easy way to clear all Contributor history / start a new?
I have tried copying in a fresh TM1 server without the control objects, and also re-creating the tomcat application from the war file with no luck.
Looking at the server, those Contributor control object re-appear.
Re: TM1 Contributor - approval heirachy is being used
Posted: Mon Feb 01, 2010 4:18 am
by rollo19
Process tp_admin_delete_all cleans it up - thanks JW
Posted: Sat Feb 06, 2010 6:42 pm
by David
JW,
I am new to TM1. Can you explain a little more details on how to run }tp_admin_delete_all?
David
Posted: Sun Feb 07, 2010 8:25 pm
by rollo19
Display > control objects & you will see the process }tp_admin_delete_all, note the script deletes all the contributor control cubes & dims. Handy if you want to start afresh.
Posted: Wed Feb 10, 2010 3:28 am
by David
Hmm, I cannot find }tp_admin_delete_all at all
Posted: Wed Feb 10, 2010 3:35 am
by rollo19
Are you using contributor over this model?
Posted: Wed Feb 10, 2010 3:58 am
by David
Yes, I had created a contributor application using this model on the server. I copied the whole model to another machine and tried to created another contributor there, but received the error message. Thank you for your time.
Posted: Wed Feb 10, 2010 9:02 am
by DuangpornT
It's a TI Process, pls move down at "Processes"
Posted: Wed Feb 10, 2010 3:42 pm
by David
Thanks all. I found it.
