TM1 Contributor Installation on XP
David
Version: 9.4
Post by David »
I am having a issue with the TM1 Conributor installation- cannot open the Contributor admin (see scree-print).
TM1 Install Err.JPG (59.19 KiB) Viewed 3867 times
I had a PMR with Cognos support and they could not find a solution for me and pointed out the XP is not a supported platform for Contributor. I wonder if there is anyone successfully installed/configured the TM1 9.5 Contributor in the XP machine. I used WebSphere Application Server Community Edition Version instead Tomcat to deploy the appliation.
David
Christian
Version: 9.4
Re: TM1 Contributor Installation on XP
Post by Christian »
Hi David...I have installed 9.5 Contrib on XP a few times now. I've used Apache/Tomcat each time and it's worked fine.
David
Version: 9.4
Post by David »
Thank you Christian! I will try it out.
rkaif
OLAP Product: IBM Cognos TM1
Version: 9.1 or later
Excel Version: 2003 or later
Post by rkaif »
I have installed TM1 9.5 Contributor on Windows 2003 (SP2) with Apache and it works fine.
If you have deployed Contributor over Apache then make sure you have made following changes to the tomcat-users.xml file.
<?xml version='1.0' encoding='utf-8'?>
You have to first uninstall the WebSphere before installing Apache.
Cheers!
Rizwan Kaif
