Schedule chore for a specific time
mbeckw
Version: 10.1.1
Post by mbeckw »
I would like to have a chore run only M-F from 8am to 6pm. I would imagine I put the syntax in the prolog tab of the TI process I am running in the chore. Can anyone help me with the syntax. I would be forever greatful.
Mark
TM1 version 9.1 using excel 2003
Version: PA 2.0.7
Re: Schedule chore for a specific time
Post by jim wood »
There is a more simple but messy option which is to create a schedule for each day?
mbeckw
Version: 10.1.1
Post by mbeckw »
Thanks Jim. I did think about doing that but there is not an option to schedule the chore to only run it from 8am to 6pm. Do you know how to do that?
ajain86
Version: 9.4.1 9.5 9.5.1
Excel Version: 2003 2007
Post by ajain86 »
To limit to 8 am to 6 pm, you can do an if statement to check current time and only proceed if it is in between the desired time.
so:
assuming you are running the chore once an hour.
# to get the current hour
sTime = SUBST(TIME,1,2);
# convert to number to easily to comparison
nTime = StringToNumber(sTime,2,0);
# make sure to account for GMT and your time zone.
if (nTime > 8 & nTime < 18);
execute....
endif;
You would have to schedule it to run every hour. I am not aware of a function to get the day of the week.
Ankur Jain
mbeckw
Version: 10.1.1
Post by mbeckw »
I assume I would put this in the prolog tab of the TI process?
ajain86
Post by ajain86 »
Yes.
Ankur Jain
LoadzaGrunt
Version: LoadzaVersions
Excel Version: LoadzaVersions
Post by LoadzaGrunt »
There isn't one - use a combination of DAYNO and MOD to find out the day of the week.
LoadzaGrunt wrote:There isn't one - use a combination of DAYNO and MOD to find out the day of the week.
To handle the weekday lookup you can also have a "system days" lookup dimension which is just all dates in yyyy-mm-dd format and hold attributes against the dimension for situations such as this. Then to return the day of the week you just need something like AttrS('System Date', TODAY(1), 'Weekday').
As Peter K posted recently time based lookup attributes are really really easy to calculate in Excel and send in and this is a once off setup task that never needs to be repeated.
Specifically:
# Returns 0 = Sunday to 6 = Saturday.
l_DayOfWeek= Mod ( DayNo( TODAY ) + 21915, 7);
kangkc
Version: 2.x
Excel Version: 36x
Post by kangkc »
We took it to the extreme. We built a calendar schedule cube with calendar date/timing. Add in a common code in the prolog for all the processes to check this cube before executing. With this we can have full control when to execute certain processes.
Sandhya Kumar
Version: 9.0 and above
Post by Sandhya Kumar »
If you can use an external scheduling tool like Autosys, you can make use of this option- TM1ChoreExecute.exe. This will be present in the tm1\bin folder and we can create an Autosys job with the below command and specify schedule of our choice:
<<dir location>>\TM1ChoreExecute.exe AdminServer TM1Server UserID Password ChoreName
appleglaze28
Post by appleglaze28 »
I would like to clarify something with the setting of the time.
For example the time in my country is GMT+8 3:54PM but base on the chore the GMT time is 7:54AM.
I've been trying to work out the time but I can't seem to understand how to set the time to run from with 3-4PM. The only time set I was able to work on is 14:00 - 16:00. I was thinking I have to set the time as local time zone time less 1 but It doesn't work on 14:00 - 15:00. It wants 2 hours for allotment for it to run.
if (nTime > 14 & nTime < 16);
Am I right or wrong about this?
It helps if you indicate where you're deriving values like nTime from.
If you're getting it from TI's date and time functions, like so:
nTime = TimVl( Now(), 'H') ;
then the time zone that you're in is immaterial. Although log files are recorded in UTC, although chores are irritatingly scheduled in UTC, the time and date functions work from the local time. Thus the code above for me (where it is 7:36pm as I type this, or 19:36 in military time), yields 19.
appleglaze28 wrote: It wants 2 hours for allotment for it to run.
You might want to look at your code a little more closely. That's not a 2 hour allotment, that's only a 1 hour allotment. Remember that you're only testing the hour component (as far as I can tell), not the actual time. If it has to be greater than 14 but less than 16, then the hour can only be... 15. In other words it will run between 3:00:00pm and 3:59:59pm. It would probably be easier to express it as:
if (nTime = 15);
