Schedule chore for a specific time
mbeckw
- Version: 10.1.1
I would like to have a chore run only M-F from 8am to 6pm. I would imagine I put the syntax in the prolog tab of the TI process I am running in the chore. Can anyone help me with the syntax. I would be forever greatful.
Mark
Mark
TM1 version 9.1 using excel 2003
- jim wood
- Version: PA 2.0.7
Re: Schedule chore for a specific time
There is a more simple but messy option which is to create a schedule for each day?
mbeckw
- Version: 10.1.1
Thanks Jim. I did think about doing that but there is not an option to schedule the chore to only run it from 8am to 6pm. Do you know how to do that?
ajain86
- Version: 9.4.1 9.5 9.5.1
- Excel Version: 2003 2007
To limit to 8 am to 6 pm, you can do an if statement to check current time and only proceed if it is in between the desired time.
so:
assuming you are running the chore once an hour.
# to get the current hour
sTime = SUBST(TIME,1,2);
# convert to number to easily to comparison
nTime = StringToNumber(sTime,2,0);
# make sure to account for GMT and your time zone.
if (nTime > 8 & nTime < 18);
execute....
endif;
You would have to schedule it to run every hour. I am not aware of a function to get the day of the week.
so:
execute....
endif;
Ankur Jain
mbeckw
- Version: 10.1.1
I assume I would put this in the prolog tab of the TI process?
- LoadzaGrunt
- Version: LoadzaVersions
- Excel Version: LoadzaVersions
There isn't one - use a combination of DAYNO and MOD to find out the day of the week.I am not aware of a function to get the day of the week.
To handle the weekday lookup you can also have a "system days" lookup dimension which is just all dates in yyyy-mm-dd format and hold attributes against the dimension for situations such as this. Then to return the day of the week you just need something like AttrS('System Date', TODAY(1), 'Weekday').LoadzaGrunt wrote:There isn't one - use a combination of DAYNO and MOD to find out the day of the week.
As Peter K posted recently time based lookup attributes are really really easy to calculate in Excel and send in and this is a once off setup task that never needs to be repeated.
Specifically:LoadzaGrunt wrote:There isn't one - use a combination of DAYNO and MOD to find out the day of the week.I am not aware of a function to get the day of the week.
# Returns 0 = Sunday to 6 = Saturday.
l_DayOfWeek= Mod ( DayNo( TODAY ) + 21915, 7);
kangkc
- Version: 2.x
- Excel Version: 36x
We took it to the extreme. We built a calendar schedule cube with calendar date/timing. Add in a common code in the prolog for all the processes to check this cube before executing. With this we can have full control when to execute certain processes.
Sandhya Kumar
- Version: 9.0 and above
If you can use an external scheduling tool like Autosys, you can make use of this option- TM1ChoreExecute.exe. This will be present in the tm1\bin folder and we can create an Autosys job with the below command and specify schedule of our choice:
<<dir location>>\TM1ChoreExecute.exe AdminServer TM1Server UserID Password ChoreName
appleglaze28
For example the time in my country is GMT+8 3:54PM but base on the chore the GMT time is 7:54AM.
I've been trying to work out the time but I can't seem to understand how to set the time to run from with 3-4PM. The only time set I was able to work on is 14:00 - 16:00. I was thinking I have to set the time as local time zone time less 1 but It doesn't work on 14:00 - 15:00. It wants 2 hours for allotment for it to run.
if (nTime > 14 & nTime < 16);
It helps if you indicate where you're deriving values like nTime from.appleglaze28 wrote:I would like to clarify something with the setting of the time.Code: Select all
# make sure to account for GMT and your time zone. if (nTime > 8 & nTime < 18);
If you're getting it from TI's date and time functions, like so:
nTime = TimVl( Now(), 'H') ;You might want to look at your code a little more closely. That's not a 2 hour allotment, that's only a 1 hour allotment. Remember that you're only testing the hour component (as far as I can tell), not the actual time. If it has to be greater than 14 but less than 16, then the hour can only be... 15. In other words it will run between 3:00:00pm and 3:59:59pm. It would probably be easier to express it as:appleglaze28 wrote: It wants 2 hours for allotment for it to run.
Am I right or wrong about this?Code: Select all
# make sure to account for GMT and your time zone. if (nTime > 14 & nTime < 16);
if (nTime = 15);"To them, equipment failure is terrifying. To me, it’s 'Tuesday.' "
