Compile Error in Hidden Module : frmtaskActions : TM1 Workfl
Posted: Thu Nov 05, 2009 10:59 am
We installed workflow 9.4 successfully. However, we are not able to load the workflow.
When we click on Admin button, the VB error dialog bix is displayed with following message.
"Compile Error in Hidden Module : frmtaskActions"
We had installed workflow during out training and it was working without any issues.
Any pointers on this?
We received a following solution but that didn't work because the Compatibility Flags were not available for any one of the keys.
Apparently, it has to do with a Microsoft Security patch applied to your operating system. To fix it, see the instructions below. You will need to edit your registry:
Open the registry using REGEDIT and check the following keys:
check the four Windows Registry Keys
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\ActiveX Compatibility\
{2C247F23-8591-11D1-B16A-00C0F0283628}
{BDD1F04B-858B-11D1-B16A-00C0F0283628}
{C74190B6-8589-11D1-B16A-00C0F0283628}
{0ECD9B64-23AA-11D0-B351-00A0C9055D8E}
have set their "Compatibility Flags" DWORD value set to 0 on all of the above keys
We have few more questions.
__Workflow Prerequisites.__
If you are installing Workflow against an existing TM1 database:
†The existing TM1 database must have a dimension that holds the names
of budget versions. Without an existing version dimension, you cannot
run Workflow.
How do you take care of this?
Licensing
TM1 Workflow requires TM1 9.4 or later. You must have the following options
enabled in your TM1 Server license:
• TM1 Server
• TurboIntegrator
• TM1 Workflow
How do you take care of this? Which screen/license do we need to change? how? There is no such guidance in the document...
Any pointers?
Thanks & Regards
Milind
run Workflow.
Licensing
• TM1 Server
• TurboIntegrator
• TM1 Workflow
Any pointers?
Thanks & Regards
Milind
