Compile Error in Hidden Module : frmtaskActions : TM1 Workfl
milind_chavan
Version: 9.4
Post by milind_chavan »
We installed workflow 9.4 successfully. However, we are not able to load the workflow.
When we click on Admin button, the VB error dialog bix is displayed with following message.
"Compile Error in Hidden Module : frmtaskActions"
We had installed workflow during out training and it was working without any issues.
Any pointers on this?
We received a following solution but that didn't work because the Compatibility Flags were not available for any one of the keys.
Apparently, it has to do with a Microsoft Security patch applied to your operating system. To fix it, see the instructions below. You will need to edit your registry:
Open the registry using REGEDIT and check the following keys:
check the four Windows Registry Keys
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\ActiveX Compatibility\
{2C247F23-8591-11D1-B16A-00C0F0283628}
{BDD1F04B-858B-11D1-B16A-00C0F0283628}
{C74190B6-8589-11D1-B16A-00C0F0283628}
{0ECD9B64-23AA-11D0-B351-00A0C9055D8E}
have set their "Compatibility Flags" DWORD value set to 0 on all of the above keys
We have few more questions.
__Workflow Prerequisites.__
If you are installing Workflow against an existing TM1 database:
‐ The existing TM1 database must have a dimension that holds the names
of budget versions. Without an existing version dimension, you cannot
run Workflow.
How do you take care of this?
Licensing
TM1 Workflow requires TM1 9.4 or later. You must have the following options
enabled in your TM1 Server license:
• TM1 Server
• TurboIntegrator
• TM1 Workflow
How do you take care of this? Which screen/license do we need to change? how? There is no such guidance in the document...
Any pointers?
Thanks & Regards
Milind
kangkc
Version: 2.x
Excel Version: 36x
Re: Compile Error in Hidden Module : frmtaskActions : TM1 Workfl
Post by kangkc »
rodrigo
OLAP Product: TM1, Executive Viewer
Version: 9.4 MR1 with FP3
Post by rodrigo »
I had the same problem, you didnt need all four keys, I tried this on a Windows Server 2003 and on Win XP
The key i found on regedit, on Activex Compatibility was: {0ECD9B64-23AA-11D0-B351-00A0C9055D8E}
I modified the way I am describing to you on the attached picture and it is working fine. I never solved this problem removing or reinstalling Microsoft KB´s, I never found those.
I know this is probably not your answer, but that method worked for me.
Jessy
Version: 9.4.1
Post by Jessy »
The same problem for me.
milind_chavan wrote:Open the registry using REGEDIT and check the following keys:
I followed the instructions above and only found the key {0ECD9B64-23AA-11D0-B351-00A0C9055D8E} , after I changed the "Compatibility Flags" DWORD value to 0, my workflow works well now.
Thank you!
andre lie
Post by andre lie »
I change the compatibility flags for {0ECD9B64-23AA-11D0-B351-00A0C9055D8E} DWORD to 0 (it is the only key among four keys mentioned that have the compatibility flags)
Now I can click Admin button to open TM1 Workflow Administration Console and other buttons BUT the 'Load' button (despite the Load button working well from TM1 Web)
When I click the Load button in Excel, i get this message:
workflow error1.jpg (27.44 KiB) Viewed 9887 times
TheerapatC
OLAP Product: Cognos
Version: TM1
Post by TheerapatC »
UnInstall Windows Update (KB973346)
Otherwise TM1 Workflow will not work properly.
andre lie
Post by andre lie »
I uninstall KB973346 but still get the same error message when i click the Load button
Rgds
DuangpornT
Version: 9.5
Excel Version: 2007 SP2
Post by DuangpornT »
andre lie wrote:I uninstall KB973346 but still get the same error message when i click the Load button
Rgds
pls try to uninstall windows update KB960715 ,too.
ref : http://forums.olapforums.com/viewtopic. ... bits#p7544
andre lie
Post by andre lie »
Yes I have uninstalled both : KB973346 and KB960715 with no success
Rgds
