MDX for current and previous month
Posted: Thu Oct 16, 2025 3:50 pm
by M1ndbender
I have a period dimension that is by day. days roll up to months, months to quarters and quarters to years.
I am trying to create dynamic mdx that will return the current month and previous month
This works to return the current month
FILTER(TM1SUBSETALL([report_HDD_fiscalPeriodByDay]) , [report_HDD_fiscalPeriodByDay].CURRENTMEMBER.NAME = [CONTROL].([Control Parameters].[Current Month],[CONTROL_m].[S-Value]))
And this works for previous month if I hard code CURRENTMEMBER.NAME to the current month
FILTER(TM1SUBSETALL([report_HDD_fiscalPeriodByDay]) , [report_HDD_fiscalPeriodByDay].CURRENTMEMBER.NAME = [report_HDD_fiscalPeriodByDay].CURRENTMEMBER.PROPERTIES("PreviousPeriod"))
Is there a way to combine these so it will bring back current and previous at the same time?
Re: MDX for current and previous month
Posted: Thu Oct 16, 2025 4:09 pm
by MarenC
either of these should work, but there are lots of different ways:
FILTER(TM1SUBSETALL([report_HDD_fiscalPeriodByDay]) , [report_HDD_fiscalPeriodByDay].CURRENTMEMBER.NAME = [CONTROL].([Control Parameters].[Current Month],[CONTROL_m].[S-Value])) + FILTER(TM1SUBSETALL([report_HDD_fiscalPeriodByDay]) , [report_HDD_fiscalPeriodByDay].CURRENTMEMBER.NAME = [report_HDD_fiscalPeriodByDay].CURRENTMEMBER.PROPERTIES("PreviousPeriod"))
FILTER(TM1SUBSETALL([report_HDD_fiscalPeriodByDay]) , [report_HDD_fiscalPeriodByDay].CURRENTMEMBER.NAME = [CONTROL].([Control Parameters].[Current Month],[CONTROL_m].[S-Value]) or [report_HDD_fiscalPeriodByDay].CURRENTMEMBER.NAME = [report_HDD_fiscalPeriodByDay].CURRENTMEMBER.PROPERTIES("PreviousPeriod"))
Maren
Posted: Thu Oct 16, 2025 4:13 pm
by gtonkin
How about using StrToMember to derive the members based on the text in the control cube or attribute?
You can then just separate each derived member with a comma and enclose in braces to return both in a set.
StrToMember("[report_HDD_fiscalPeriodByDay].[" +
[CONTROL].([Control Parameters].[Current Month],[CONTROL_m].[S-Value] + "]"),
	  "]").PROPERTIES("PreviousPeriod") + "]")
Posted: Thu Oct 16, 2025 4:31 pm
by M1ndbender
That seems to have worked perfectly. Thank you so much for your help.
Posted: Thu Oct 16, 2025 7:02 pm
by gtonkin
Pleasure - glad it worked!
Posted: Sat Oct 18, 2025 4:51 pm
by Wim Gielis
Also you might want to consider the MDX function LastPeriods with a value of -2, if element indexes behave correctly.
