MDX for current and previous month
M1ndbender
Version: 2.0.0
Excel Version: 365
Post by M1ndbender »
I have a period dimension that is by day. days roll up to months, months to quarters and quarters to years.
I am trying to create dynamic mdx that will return the current month and previous month
This works to return the current month
FILTER(TM1SUBSETALL([report_HDD_fiscalPeriodByDay]) , [report_HDD_fiscalPeriodByDay].CURRENTMEMBER.NAME = [CONTROL].([Control Parameters].[Current Month],[CONTROL_m].[S-Value]))
And this works for previous month if I hard code CURRENTMEMBER.NAME to the current month
FILTER(TM1SUBSETALL([report_HDD_fiscalPeriodByDay]) , [report_HDD_fiscalPeriodByDay].CURRENTMEMBER.NAME = [report_HDD_fiscalPeriodByDay].CURRENTMEMBER.PROPERTIES("PreviousPeriod"))
Is there a way to combine these so it will bring back current and previous at the same time?
MarenC
Excel Version: Excel 2016
Re: MDX for current and previous month
Post by MarenC »
either of these should work, but there are lots of different ways:
FILTER(TM1SUBSETALL([report_HDD_fiscalPeriodByDay]) , [report_HDD_fiscalPeriodByDay].CURRENTMEMBER.NAME = [CONTROL].([Control Parameters].[Current Month],[CONTROL_m].[S-Value])) + FILTER(TM1SUBSETALL([report_HDD_fiscalPeriodByDay]) , [report_HDD_fiscalPeriodByDay].CURRENTMEMBER.NAME = [report_HDD_fiscalPeriodByDay].CURRENTMEMBER.PROPERTIES("PreviousPeriod"))
FILTER(TM1SUBSETALL([report_HDD_fiscalPeriodByDay]) , [report_HDD_fiscalPeriodByDay].CURRENTMEMBER.NAME = [CONTROL].([Control Parameters].[Current Month],[CONTROL_m].[S-Value]) or [report_HDD_fiscalPeriodByDay].CURRENTMEMBER.NAME = [report_HDD_fiscalPeriodByDay].CURRENTMEMBER.PROPERTIES("PreviousPeriod"))
Maren
How about using StrToMember to derive the members based on the text in the control cube or attribute?
You can then just separate each derived member with a comma and enclose in braces to return both in a set.
StrToMember("[report_HDD_fiscalPeriodByDay].[" +
[CONTROL].([Control Parameters].[Current Month],[CONTROL_m].[S-Value] + "]"),
	  "]").PROPERTIES("PreviousPeriod") + "]")
BR, George.
M1ndbender
Version: 2.0.0
Excel Version: 365
That seems to have worked perfectly. Thank you so much for your help.
Pleasure - glad it worked!
BR, George.
Also you might want to consider the MDX function LastPeriods with a value of -2, if element indexes behave correctly.
