I have a form that I can enter into as Admin, but users cannot. I have looked to ensure the users are in the proper write group, there is proper cube security, there is no dimension or element security on any of the dimensions or measures, there is no locks or holds, and the users are not set to read only.
I basically went through all the steps outlined in Wim Gielis's blog post and the users still can't enter in data. (https://www.wimgielis.com/tm1_cellchange_EN.htm)
Any advice on where to look next?
Users unable to direct enter into a form
M1ndbender
- Version: 2.0.0
- Excel Version: 365
- Steve Rowe
Re: Users unable to direct enter into a form
There's really only a couple of options here.
1. It is security and you've missed something in your analysis. It can't be locking as that would be impacting Admins too.
2. The view you're using as admin and as end user is different (i.e. consolidated / not at the lowest level) and so the cell is not updateable.
I don't think there are any other options really.
MarenC
- Excel Version: Excel 2016
I guess the only other thing is to run Security Refresh in case you haven't.
Maren
Maren
M1ndbender
- Version: 2.0.0
Thank you for the responses. I will keep digging
burnstripe
- Version: 2.0.9
Don't know if this setting applies to admins or not and whether it would fit what about the "Allow Write Back from tm1web" setting per the screenshot attached. It might be set to disallow
- Screenshot_20250807_174835.jpg (225.54 KiB) Viewed 317073 times
JohnO
- Version: 2.0.9.x
- Excel Version: Office 365 16
Cell security?M1ndbender wrote: ↑Wed Aug 06, 2025 7:05 pm I have looked to ensure the users are in the proper write group, there is proper cube security, there is no dimension or element security on any of the dimensions or measures, there is no locks or holds, and the users are not set to read only.
Do you have a test environment where the users have access and where you can remove security stepwise (Refreshing security after each removal)?
M1ndbender
- Version: 2.0.0
It was cell security after all. We have a high level dimension product that then has sub dimensions like budget_product etc. It was the lowest level dimension that had the cell security on it.
Thank you for all the help
MarenC
So when you said,
Basically meant, not really!I basically went through all the steps outlined in Wim Gielis's blog post and the users still can't enter in data.
