IBM PAW IDLE Session Timeout
Posted: Mon Jun 03, 2024 1:18 pm
by PrabhjotSinghPhull
Hi Team
Hope youre doing well.
PAW version 2.0.87
I have referred the IBM article and updated the session timeout.
Step 1 : Stopped the PAW service by using running Paw.ps1 stop via powershell as admin from Scripts folder in installation directory.
Step 2 : Updated paw.ps1 files in Config folder in Installation directory.
Step 3 : Started PAW service by using running Paw.ps1 start via powershell from Scripts folder in installation directory.
Step 4 : login in PAW minimize the screen for 15 mins to check the idle session time out thing it is not working.
result : the PAW session didnt get timed out.
Refernces used :
PLANNING ANALYTICS WORKSPACE IDLE TIMEOUT:
Default: 60m ( 60 minutes )
Setting: SessionTimeout
https://www.ibm.com/support/knowledgece ... _file.html
Prabhjot Singh
Re: IBM PAW IDLE Session Timeout
Posted: Mon Jun 03, 2024 1:33 pm
by Steve Rowe
What's your question though?
Posted: Mon Jun 03, 2024 3:31 pm
Steve Rowe wrote: ↑Mon Jun 03, 2024 1:33 pm What's your question though?
Hi Steve
PAW session timeout is not working after updating the parameter
Posted: Mon Jun 03, 2024 4:04 pm
by gtonkin
Is your PAW running on Windows or Linux?
And you specified SessionTimeout="15m" - ensuring case is same?
Posted: Tue Jun 04, 2024 6:28 am
gtonkin wrote: ↑Mon Jun 03, 2024 4:04 pm Is your PAW running on Windows or Linux?
Yes correct the Windowserver 2016 and have written in below format.
$env:SessionTimeout="15m"
In config folder the default.ps1 file still the parameter is 60m which was supposed to over ride after stop and start the paw.ps1 and its not overriding it.
