Hi Team
Hope youre doing well.
PAW version 2.0.87
I have referred the IBM article and updated the session timeout.
Step 1 : Stopped the PAW service by using running Paw.ps1 stop via powershell as admin from Scripts folder in installation directory.
Step 2 : Updated paw.ps1 files in Config folder in Installation directory.
Step 3 : Started PAW service by using running Paw.ps1 start via powershell from Scripts folder in installation directory.
Step 4 : login in PAW minimize the screen for 15 mins to check the idle session time out thing it is not working.
result : the PAW session didnt get timed out.
Refernces used :
PLANNING ANALYTICS WORKSPACE IDLE TIMEOUT:
Default: 60m ( 60 minutes )
Setting: SessionTimeout
https://www.ibm.com/support/knowledgece ... _file.html
Prabhjot Singh
IBM PAW IDLE Session Timeout
PrabhjotSinghPhull
- OLAP Product: IBM PA
- Version: 9.5
Last edited by PrabhjotSinghPhull on Mon Jun 03, 2024 3:29 pm, edited 1 time in total.
- Steve Rowe
PrabhjotSinghPhull
- Version: 9.5
Re: IBM PAW IDLE Session Timeout
Hi Steve
PAW session timeout is not working after updating the parameter
- gtonkin
Is your PAW running on Windows or Linux?
And you specified SessionTimeout="15m" - ensuring case is same?
PrabhjotSinghPhull
- Version: 9.5
Yes correct the Windowserver 2016 and have written in below format.
$env:SessionTimeout="15m"
In config folder the default.ps1 file still the parameter is 60m which was supposed to over ride after stop and start the paw.ps1 and its not overriding it.
