unable to use advanced rule editor after PA 2.0.7
wang_chris
Post by wang_chris »
I have installed PA 2.0.9.19, and found that only basic rule editor can be run in architect. i tried to set 'AdvancedRulesEditor' in tm1p.ini, however it doesn't work as expected, and IBM online document mentioned that advanced rule editor was deperciated since PA 2.0.7.
Is there any workaround to use advanced rule editor in PA 2.0.7, and later version?
Elessar
OLAP Product: PA 2
Version: 2.0.9
Re: unable to use advanced rule editor after PA 2.0.7
Post by Elessar »
No. But if you have a distributive for PA 2.0.7 (client) or older, you can install old Architect separately
wang_chris
can i just replace tm1a.exe with old version one, rather than resinstall architect again with olde version?
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
I don't think so, but have not tried.
You do not need to reinstall architect: just install another one in another folder
JohnO
Version: 2.0.9.x
Excel Version: Office 365 16
Post by JohnO »
wang_chris wrote: ↑Tue May 21, 2024 1:18 pm I have installed PA 2.0.9.19, and found that only basic rule editor can be run in architect. i tried to set 'AdvancedRulesEditor' in tm1p.ini, however it doesn't work as expected, and IBM online document mentioned that advanced rule editor was deperciated since PA 2.0.7.
2.0.96 PAW is supposed to have multiple improvements in the rule editor. Less than 1 year until end of support for Architect etc ......
