I have installed PA 2.0.9.19, and found that only basic rule editor can be run in architect. i tried to set 'AdvancedRulesEditor' in tm1p.ini, however it doesn't work as expected, and IBM online document mentioned that advanced rule editor was deperciated since PA 2.0.7.
Is there any workaround to use advanced rule editor in PA 2.0.7, and later version?
unable to use advanced rule editor after PA 2.0.7
wang_chris
- Version: 10.2
- Elessar
- OLAP Product: PA 2
- Version: 2.0.9
Re: unable to use advanced rule editor after PA 2.0.7
No. But if you have a distributive for PA 2.0.7 (client) or older, you can install old Architect separately
wang_chris
- Version: 10.2
can i just replace tm1a.exe with old version one, rather than resinstall architect again with olde version?
- Elessar
- Version: 2.0.9
I don't think so, but have not tried.
You do not need to reinstall architect: just install another one in another folder
JohnO
- Version: 2.0.9.x
- Excel Version: Office 365 16
2.0.96 PAW is supposed to have multiple improvements in the rule editor. Less than 1 year until end of support for Architect etc ......wang_chris wrote: ↑Tue May 21, 2024 1:18 pm I have installed PA 2.0.9.19, and found that only basic rule editor can be run in architect. i tried to set 'AdvancedRulesEditor' in tm1p.ini, however it doesn't work as expected, and IBM online document mentioned that advanced rule editor was deperciated since PA 2.0.7.
