Server replication error
medohassan
Version: 9.0
Post by medohassan »
Dear Expertise,
I have two servers in two differant locations and I am admin for both, but i can't run replications as it return ERROR: SystemServerNotFound. is it because of they are in defferent domain? as i copied one of them to creat another server on the same server and I had a successful replication. Please let me know your thoughts about that. Regards
Version: PA 2.0.7
Re: Server replication error
Post by jim wood »
Can't remember whether to replicate you're instance need to be using the same admin host? If not being on different might be the problem. Can you reach one box from the other???
Steve Vincent
Version: 10.2.2 FP1
Post by Steve Vincent »
both services need to have the same admin host stipulated in their config files. if they are not broadcasting to the same one you will get "unexpected results", to quote the TM1 manual.
medohassan
Version: 9.0
Thanks a lot you have been a great help for me. it is working now after adding adminHost server IPs. Thanks a lot
