Dear Expertise,
I have two servers in two differant locations and I am admin for both, but i can't run replications as it return ERROR: SystemServerNotFound. is it because of they are in defferent domain? as i copied one of them to creat another server on the same server and I had a successful replication. Please let me know your thoughts about that. Regards
Server replication error
medohassan
- Version: 9.0
- Excel Version: 2003
- jim wood
- Version: PA 2.0.7
Re: Server replication error
Can't remember whether to replicate you're instance need to be using the same admin host? If not being on different might be the problem. Can you reach one box from the other???
- Steve Vincent
- Version: 10.2.2 FP1
both services need to have the same admin host stipulated in their config files. if they are not broadcasting to the same one you will get "unexpected results", to quote the TM1 manual.
medohassan
- Version: 9.0
Thanks a lot you have been a great help for me. it is working now after adding adminHost server IPs. Thanks a lot
