Update a process with the TM1 REST API
I am trying to use Postman to update an existing, very simple, TI process.
The only line of code is: v = 1; in the Prolog tab. No data source, no variables, etc.
I want to update the process to read: v = 2; Can it be even more simple ? :-) The process is called 'test'. TM1 basic security, I am admin for the test.
PAL 2.0.9.10.
So I have this:
GET: http://AEX220:8001/api/v1/Processes('test')
Result:
    "@odata.context": "$metadata#Processes/$entity",
    "@odata.etag": "W/\"322acd39b78e9283c769d29d901f4c3e04792b58\"",
    "Name": "test",
    "HasSecurityAccess": false,
    "PrologProcedure": "\r\n#****Begin: Generated Statements***\r\n#****End: Generated Statements****\r\n\r\n\r\nv = 1;",
    "MetadataProcedure": "\r\n#****Begin: Generated Statements***\r\n#****End: Generated Statements****",
    "DataProcedure": "\r\n#****Begin: Generated Statements***\r\n#****End: Generated Statements****",
    "EpilogProcedure": "\r\n#****Begin: Generated Statements***\r\n#****End: Generated Statements****",
    "DataSource": {
        "Type": "None"
    "Parameters": [],
    "Variables": [],
    "Attributes": {
        "Caption": "test"
I change the v = 1 into v = 2 and I copy the whole lot into the JSON body for a PATCH statement, I get an error for "Bad request":
    "error": {
        "code": "278",
        "message": "Cannot modify Attributes property during Process PATCH."
(see below for a picture)
When I then manually delete the Attributes part in the JSON body and send the PATCH request again, it works:
    "Name": "test",
    "PrologProcedure": "\r\n#****Begin: Generated Statements***\r\n#****End: Generated Statements****\r\n\r\n\r\nv = 2;",
    "DataSource": {
        "Type": "None"
    "Parameters": [],
    "Variables": []
The process is not part of any chore.
Did any of you encounter it before ? When I reverse engineer in tm1py, it does not seem to me that tm1py is doing anything with the body of the request. Certainly nothing with Attributes. Any help is greatly appreciated !
Thanks.
bad request.PNG (69.55 KiB) Viewed 7495 times
Re: Update a process with the TM1 REST API
Marius Wirtz confirms that we should not do anything with the Attributes property when updating a process.
Either we strip it from the JSON body (result of a GET call), either we select the process properties we need (and exclude the Attributes property from that list).
dan.kelleher
Version: 9.4
Excel Version: 11
Post by dan.kelleher »
Another solution I have found is to simply delete the existing process from the target server and then re-add:
$url = $url = "http://${targetServer}:${TargetPort}/api/v1/Processes('$processName')"
$header = Set-Header $targetUser $targetPass
$response = Invoke-WebRequest -Uri $url -Method Delete -Headers $header
$response = Invoke-WebRequest -Uri $url -Method Put -Headers $header -Body $body
Does anyone know if there's a way to remove the Attributes property from the initial GET?
What happens to the security assignments for the process, when you delete and recreate ?
In general, I try to update rather than recreate, to not lose other settings.
Another example, data against the process in the }Processes dimension in a cube: is it lost or not, when deleting and recreating ?
dan.kelleher
Version: 9.4
Excel Version: 11
Yes, these are lost so need to be re-added, which is probably more work than removing the attributes property from the body.
dan.kelleher
Version: 9.4
Excel Version: 11
Just in case anyone's interested, I worked out how to remove the attributes property via Powershell:
$response = Invoke-WebRequest -Uri $url -Method Get -Headers $header
$x = $response.content | ConvertFrom-Json
$x = $x | Select-Object * -ExcludeProperty Attributes
$body = $x | ConvertTo-Json
$header = Set-Header $targetEncodedText
$response = Invoke-WebRequest -Uri $url -Method Patch -Headers $header -Body $body
Good, elegant, solution.
Minor remark, you have the $url = part twice.
