Could not initialize process : Incorrect type for parameter
vasek1192
OLAP Product: IBM Planning analytics
Version: 2.0.9.3
Excel Version: 2019
Post by vasek1192 »
I got stuck with this little problem and would appreciate any kind of help or advice.
I am executing a subprocess through another process. The master process supplies the subprocess with parameters from data source (cube) variables.
The subprocess then executes CellInctrementN function into different cube.
ExecuteProcessLine:
ExecuteProcess('L_OO_JN_6MK_zadavaci_JN_6MK_Vkladaci', 'psVerze', psVerze, 'psMaska', sMaska, 'psRozlozenost', sRozlozenost, 'psZavod', sZavod, 'psDruhyVozu', sDruhy_Vozu, 'psTemata', sTemata, 'psMesic', vsMetrika, 'psMetrika', vsG_OO_JN_6MK, 'pnValue', vnValue);
CellIncremenetN line
CellIncrementN(pnValue, sTargetCube, vsH_Zeme, vsH_Rozlozenost, vsH_Vozy_6MK, vsG_Zavod, vsG_Druhy_Vozu, vsG_Temata, psMesic, psverze, vsMetrika);
I am getting this error:
"Could not initialize process : Incorrect type for parameter 9 ("pnValue") of process "L_OO_JN_6MK_zadavaci_JN_6MK_Vkladaci", string expected"
All the measure elements in TargetCube are numeric. The data source value from the first cube is set as numeric (viz pic1). The parameter in the second cube is set as numeric (viz pic1). I am using CellIncrementN. I have no idea why he would require string value?
Any help or advice?
Data source (First cube, first process):
Source 1 problem.jpg (72.61 KiB) Viewed 2070 times
Parameters in subprocess:
Re: Could not initialize process : Incorrect type for parameter
What is vnValue set to in the parent process? Could be that it is being set to a string.
BR, George.
vasek1192
Version: 2.0.9.3
Excel Version: 2019
Post by vasek1192 »
Hi, vnValue is set as numeric in the datasource (viz first picture in original post). Some of the measure elements are string but they are filtered off from the sourceview.
