Can PA only config TLS in Web Tier?
Posted: Tue Sep 29, 2020 7:23 am
by Alex Leung
Now i have configured the Web Tier to use custom TLS but not in Data Tier.
However, i cannot find the tm1 instance when i go to "https://localhost:9514/tm1web".
Is it related to data tier not using TLS?
Seems the data transmission security overview shows that tm1 does not restrict to set both Data Tier and Web Tier to be used TLS.
https://www.ibm.com/support/knowledgece ... 20083.html
Please advise if you have related experience. Thanks a lot.
Alex
Re: Can PA only config TLS in Web Tier?
Posted: Tue Sep 29, 2020 7:42 am
by Alex Leung
For additional information, i am using Cognos security but i do not config SSL in Cognos as well.
Appreciate that if you can give me some hints.
Thanks a lot
Alex
