Now i have configured the Web Tier to use custom TLS but not in Data Tier.
However, i cannot find the tm1 instance when i go to "https://localhost:9514/tm1web".
Is it related to data tier not using TLS?
Seems the data transmission security overview shows that tm1 does not restrict to set both Data Tier and Web Tier to be used TLS.
https://www.ibm.com/support/knowledgece ... 20083.html
Please advise if you have related experience. Thanks a lot.
Alex
Can PA only config TLS in Web Tier?
Alex Leung
- Version: 2.0.6
- Excel Version: Excel 2013 32-bit
Alex Leung
- Version: 2.0.6
Re: Can PA only config TLS in Web Tier?
For additional information, i am using Cognos security but i do not config SSL in Cognos as well.
Appreciate that if you can give me some hints.
Thanks a lot
Alex
Thanks a lot
Alex
