Hello friends,
as i can read here every formula can write back in the cubes
https://www.ibm.com/support/knowledgece ... rview.html
In some sheets i just need to read the value and dont wanna write back (i have to change the formular to hardvalues cause i send the report out), but in other i want to write back directly in the cube, so i dont want to change my config evertime.
Is there an way that fits my needs?
thanks and BR
High
Excel Formula just read value without xml setting changes
Re: Excel Formula just read value without xml setting changes
A long shot maybe, but in Perspectives/Architect you can right-click a websheet > Properties > uncheck "Allow Cell Write Back from Web" ? Does this help ? See the 2nd point with item 7 on this page: http://www.wimgielis.com/tm1_cellchange_EN.htm
HighKeys
- OLAP Product: TM1 / TM1 Web / Perspectives
- Version: Planning Analytics V2.0.9
Thanks for your input, i will check this option!
Thanks!
BR
Thanks!
BR
HighKeys
Thanks, the websheet is really nice for that!
BTW if someone searching the same later, if you Disable Events you can write in the cell without writeback
BR
BR
