Excel Formula just read value without xml setting changes
HighKeys
OLAP Product: TM1 / TM1 Web / Perspectives
Version: Planning Analytics V2.0.9
Post by HighKeys »
Hello friends,
as i can read here every formula can write back in the cubes
https://www.ibm.com/support/knowledgece ... rview.html
In some sheets i just need to read the value and dont wanna write back (i have to change the formular to hardvalues cause i send the report out), but in other i want to write back directly in the cube, so i dont want to change my config evertime.
Is there an way that fits my needs?
thanks and BR
High
Re: Excel Formula just read value without xml setting changes
A long shot maybe, but in Perspectives/Architect you can right-click a websheet > Properties > uncheck "Allow Cell Write Back from Web" ? Does this help ? See the 2nd point with item 7 on this page: http://www.wimgielis.com/tm1_cellchange_EN.htm
HighKeys
Post by HighKeys »
Thanks for your input, i will check this option!
Thanks!
BR
HighKeys
Post by HighKeys »
Thanks, the websheet is really nice for that!
BTW if someone searching the same later, if you Disable Events you can write in the cell without writeback :)
BR
