Cube Views
Posted: Mon May 06, 2019 6:20 pm
by Peter Picazio
Is is possible to create a folder to store a cube view in? This is in TM1 classic, not PAX.
Re: Cube Views
Posted: Mon May 06, 2019 6:45 pm
by Alan Kirk
Peter Picazio wrote: ↑Mon May 06, 2019 6:20 pm Is is possible to create a folder to store a cube view in?
In what environment? Perspectives, the abomination that is PAW? Another interface?
Please check the Request for Assistance guidelines before posting. Questions should have FULL details.
If it's Perspectives you can put them in applications folders. You can't group then in the list of views under the cube though.
Re: Cube Views
Posted: Mon May 06, 2019 7:03 pm
by Peter Picazio
Sorry, this question pertains to TM1 classic, not PAX
Re: Cube Views
Posted: Mon May 06, 2019 7:50 pm
by Peter Picazio
I was able to create a folder under applications. Now I would like to copy a view under the new folder so that it can be shared by mulitple users.
Re: Cube Views
Posted: Mon May 06, 2019 8:41 pm
by Alan Kirk
Peter Picazio wrote: ↑Mon May 06, 2019 7:50 pm I was able to create a folder under applications. Now I would like to copy a view under the new folder so that it can be shared by mulitple users.
The relevant documentation is here. That's 10.2.2, but the principles are the same.
In short, you drag the view from under the cube and into the folder. This is of course ridiculously cumbersome if you have a long list of cubes and the one that has the view is right down the bottom. I did at one point propose a right click "Send To" option but it never went anywhere and with work on Perspectives effectively having been discontinued, it never will.
Re: Cube Views
Posted: Mon May 06, 2019 10:52 pm
by Wim Gielis
Alan Kirk wrote: ↑Mon May 06, 2019 8:41 pmThis is of course ridiculously cumbersome if you have a long list of cubes and the one that has the view is right down the bottom.
Lotsaram to the rescue !
https://www.tm1forum.com/viewtopic.php? ... ion#p61981
Re: Cube Views
Posted: Mon May 06, 2019 10:55 pm
by Alan Kirk
Wim Gielis wrote: ↑Mon May 06, 2019 10:52 pm
Ah yes, I'd forgotten about that one. To be honest I rarely move cube views into applications these days as most of the time I use active forms in there, but that is indeed a less painful way of doing it.
