Cube Views
Peter Picazio
- Excel Version: Excel version 2013
Cube Views
Is is possible to create a folder to store a cube view in? This is in TM1 classic, not PAX.
Re: Cube Views
In what environment? Perspectives, the abomination that is PAW? Another interface?Peter Picazio wrote: ↑Mon May 06, 2019 6:20 pm Is is possible to create a folder to store a cube view in?
Please check the Request for Assistance guidelines before posting. Questions should have FULL details.
If it's Perspectives you can put them in applications folders. You can't group then in the list of views under the cube though.
Peter Picazio
Re: Cube Views
Sorry, this question pertains to TM1 classic, not PAX
Peter Picazio
Re: Cube Views
I was able to create a folder under applications. Now I would like to copy a view under the new folder so that it can be shared by mulitple users.
Re: Cube Views
The relevant documentation is here. That's 10.2.2, but the principles are the same.Peter Picazio wrote: ↑Mon May 06, 2019 7:50 pm I was able to create a folder under applications. Now I would like to copy a view under the new folder so that it can be shared by mulitple users.
In short, you drag the view from under the cube and into the folder. This is of course ridiculously cumbersome if you have a long list of cubes and the one that has the view is right down the bottom. I did at one point propose a right click "Send To" option but it never went anywhere and with work on Perspectives effectively having been discontinued, it never will.
Re: Cube Views
Re: Cube Views
Ah yes, I'd forgotten about that one. To be honest I rarely move cube views into applications these days as most of the time I use active forms in there, but that is indeed a less painful way of doing it.Wim Gielis wrote: ↑Mon May 06, 2019 10:52 pmLotsaram to the rescue !
https://www.tm1forum.com/viewtopic.php? ... ion#p61981
