Hi guys,
we are experiencing weird behavior when trying to restart a TM1 instance.
It is stuck on "TM1ServerImpl::Destroy: Commit changes" and it never ends. So the only way is to kill the process itself...
In the Data folder I can see that all "StatsBy..." cubes are being overwritten (there are *.cub$ files).
How to resolve this please? Appreciate any help!
BR
Vladino
TM1 instance stuck on restart on StatsBy... cub files
- macsir
- Version: PAL 2.0.9
Re: TM1 instance stuck on restart on StatsBy... cub files
Never heard about that before. Did you manually save data before restarting?
- macsir
I think there is some conflicting between the two functions. If you use savedataall, it is unnecessary to use CubeSaveData to save all cubes.
- Excel Version: Excel 2013
I don't think that this is the reason - sometimes it is restarted successfully, but most of the times it is stuck.
Btw. when I don't run CubeSaveData and kill the process then all data changes for cubes that aren't logged are gone... This is the reason why I'm running both CubeSaveData and SaveDataAll.
- gtonkin
Are your saves in Epilog?-had issues previously with these in Prolog.
Hmm, that's interesting... It seems that it works!
Let's wait for a while if the issue is resolved. Thank you sir!
Bad news here guys... :-/
Still sometimes hangs on "Commit changes", }StatsBy... cubes hangs in "cub$" state and the only way is to kill the process manually.
Any other suggestions?
