TM1 instance stuck on restart on StatsBy... cub files
vladino
Excel Version: Excel 2013
Post by vladino »
Hi guys,
we are experiencing weird behavior when trying to restart a TM1 instance.
It is stuck on "TM1ServerImpl::Destroy: Commit changes" and it never ends. So the only way is to kill the process itself...
In the Data folder I can see that all "StatsBy..." cubes are being overwritten (there are *.cub$ files).
How to resolve this please? Appreciate any help!
BR
Vladino
macsir
Version: PAL 2.0.9
Re: TM1 instance stuck on restart on StatsBy... cub files
Post by macsir »
Never heard about that before. Did you manually save data before restarting?
vladino
Post by vladino »
macsir wrote: Wed May 02, 2018 9:13 pm Never heard about that before. Did you manually save data before restarting?
Sure, I have written a process that runs CubeSaveData for all cubes and before restarting the instance I'm also running SaveDataAll.
macsir
Version: PAL 2.0.9
Post by macsir »
I think there is some conflicting between the two functions. If you use savedataall, it is unnecessary to use CubeSaveData to save all cubes.
vladino
Post by vladino »
macsir wrote: Thu May 03, 2018 4:46 am I think there is some conflicting between the two functions. If you use savedataall, it is unnecessary to use CubeSaveData to save all cubes.
I don't think that this is the reason - sometimes it is restarted successfully, but most of the times it is stuck.
Btw. when I don't run CubeSaveData and kill the process then all data changes for cubes that aren't logged are gone... This is the reason why I'm running both CubeSaveData and SaveDataAll.
Are your saves in Epilog?-had issues previously with these in Prolog.
BR, George.
vladino
Post by vladino »
gtonkin wrote: Thu May 03, 2018 7:18 am Are your saves in Epilog?-had issues previously with these in Prolog.
Both CubeSaveData and SaveDataAll are in Prolog... I will give it a try and let you know guys, thanks!
vladino
Post by vladino »
vladino wrote: Fri May 04, 2018 12:36 pm
Hmm, that's interesting... It seems that it works! :)
Let's wait for a while if the issue is resolved. Thank you sir!
vladino
Post by vladino »
Bad news here guys... :-/
Still sometimes hangs on "Commit changes", }StatsBy... cubes hangs in "cub$" state and the only way is to kill the process manually.
Any other suggestions?
