Syntax Highlighter
John Hobson
OLAP Product: Any
Version: 1.0
Excel Version: 2020
Syntax Highlighter
Post by John Hobson »
Dominique Righetto posted a syntax highlighter for TM1 using ConTEXT ext editor
http://www.contexteditor.org/
I created a PALO version of the highlight file (attached)
Once you have installed ConTEXT just add this to the Highlighters directory.
Then either load a file with a .palo extension or load any text file and tell ConTEXT to use the palo type under "Tools" - "Set Highlighter"
Palo Highlighter.zip
Palo Syntax Highlighter
(2.17 KiB) Downloaded 959 times
John Hobson
The Planning Factory
