Dominique Righetto posted a syntax highlighter for TM1 using ConTEXT ext editor
http://www.contexteditor.org/
I created a PALO version of the highlight file (attached)
Once you have installed ConTEXT just add this to the Highlighters directory.
Then either load a file with a .palo extension or load any text file and tell ConTEXT to use the palo type under "Tools" - "Set Highlighter"
Syntax Highlighter
- John Hobson
- OLAP Product: Any
- Version: 1.0
- Excel Version: 2020
Syntax Highlighter
- Palo Highlighter.zip
- Palo Syntax Highlighter
- (2.17 KiB) Downloaded 949 times
John Hobson
The Planning Factory
