Feeders - not fed
Posted: Tue Dec 19, 2017 4:49 pm
Hi ,
I have read the IBM proven practices on feeders on recommendation of a forum member and half way through and they explain the basics clearly .
I have an issue now with my feeder not being fed and disappears on zero suppression .
I have a measure which gives the turn around time and other measure which count the cases , so I will need a variable which will calculate the total turnaround time taken for that month and divide by total number of cases for that month .
so simple rule :
SkipCheck;
['Average TurnAround Time' ] = DB('Dispute Data', !Customers SoldTo Only, !Currencies, !Months, !Dispute Case ID, !Dispute Case Status, !Dispute Person Responsible, !Dispute Processor, !Dispute Reason, !Dispute Root Cause Code, 'TurnAround Time') \ DB('Di
spute Data', !Customers SoldTo Only, !Currencies, !Months, !Dispute Case ID, !Dispute Case Status, !Dispute Person Responsible, !Dispute Processor, !Dispute Reason, !Dispute Root Cause Code, 'Cases with TurnAround');
And I have a feeder :
['TurnAround Time'] =>['Average TurnAround Time' ] ;
I just used one element in the division to feed my Average TurnAroundTime.
Now I have attached the results saying not fed , but when I click on check feeders at lowest level
Its showing up
the calculation taking the value of DB('Dispute', All dimension , 'AverageTurnArounTime');
It should take the turnaroundtime/caseswith turnaround right?
Attached both the check feeder and cube data screenshot .
I also tried to change my feeder to below as well :
['TurnAround Time'] =>DB('Dispute Data', !Customers SoldTo Only, !Currencies, !Months, !Dispute Case ID, !Dispute Case Status, !Dispute Person Responsible, !Dispute Processor, !Dispute Reason, !Dispute Root Cause Code, 'Average TurnAround Time');
But same results not fed.
Appreciating any help !!
so simple rule :
SkipCheck;
Its showing up
