Export a set of reports that iterates through the cost centre dimension
Posted: Fri Apr 28, 2017 12:32 am
I am new to TM1 but have software programming background, currently working in the TM1 support team in a government agency. We are using TM1 10.2.2, but only the support team has access to perspective, the end users can only access TM1 reports through Web. We have been asked by the end user to create a function where one can export a set of reports that iterates through the cost centre dimension to excel for their month-end performance reporting.
Currently, the month end performance pack contains 9 reports, each in a separate excel spreadsheet. The nine reports have same title dimensions (Year, version, cost centre, company). User now has to go to each of the 9 reports, select the same title dimension and snapshot it out to excel (there is a subset in the cost centre dimension that shows only the branch (consolidated) and the 3 sections (N element) the user works on, so when user exports it to snapshot, each workbook contains 4 sheets representing the 4 cost centres). Then user need to rearrange the 9 workbooks into 4 performance packs each has the 9 reports for each cost centre. - I hope it makes sense
I understand that print report wizard in the TM1 ribbon can do that, but first, the user doesnt have perspective(the excel ribbon) installed, but If it is the only constraint, we can change our policy on that. Also, using the print report, one still need to select the same title dimension 9 times and a subset needs to be name for Year and version for it to work, that is a pain.
And I found this post in the forum, looks like it is trying to do similar thing, http://www.tm1forum.com/viewtopic.php?t=5758. But I got stuck in reading this line of code "If Run("dimix", server & ":}Dimensions", myDim) = 0 Then". DIMIX is not a TM1 macro functions according to the TM1 reference guide, can we run DIMIX?
As I said before, I am really new to TM1,would be grateful if I can get some help on how can I achieve this or has anyone ever done that before?
Thanks in advance.
Thanks in advance.
