User Defined Consolidations - PAx
RSK
OLAP Product: TM1 10.1.1
Version: TM1 10.1.1
Post by RSK »
Afternoon all,
I currently have an issue with User defined consolidations within PAx, the customer has migrated their old 10.2 server to PA 2.0 where they had some views referencing a user defined consolidation. When we now attempt to pull in the view into worksheet within PAx they now error with the following message
Syntax error at or near ', ['Forecast Input Year].[CY], [Reporting.... ',
character position 799
I'm assuming the above is a MDX error message although it's not 100% obvious.
My next thought is that we could rebuild the view in PAx and publish it but there's not been much success with that.
If we create an exploration you are available to use the SUM function to add up a custom set, however when that view is saved to the model the SUM function isn't retained and the child element are all that appear in the view.
A quick report doesn't allow you to reference the user defined consolidation
When using Dynamic or Custom reports you are unable to recreate the UDC within the edit set functionality as far as I can see.
Does anyone know of a workaround of let me know if I'm missing anything obvious?
Re: User Defined Consolidations - PAx
I'm not 100% sure I am right on this but I think I remember being at a presentation where it was stated that UDCs were not yet supported but were coming.
(As I remember asking for it to be configurable option as personally I don't like users having this much control)
RSK
Version: TM1 10.1.1
Post by RSK »
Thanks Steve, I thought that would be the case.
By UDC I guess you are referring to the "Rollup" button in the subset editor? Could you just use public subsets in place of the UDCs?
